Zum Hauptinhalt wechseln
1998-2002 Honda Accord Distributor Rotor Replacement
Was du brauchst
  1. 1998-2002 Honda Accord Distributor Rotor Replacement, Distributor Cap: Schritt 1, Bild 1 von 3 1998-2002 Honda Accord Distributor Rotor Replacement, Distributor Cap: Schritt 1, Bild 2 von 3 1998-2002 Honda Accord Distributor Rotor Replacement, Distributor Cap: Schritt 1, Bild 3 von 3
    • Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
    • The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
    • Mark the order of the spark plug wires on the new distributor cap with a silver sharpie marker -- it will make reinstallation much easier.
  2. 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
    • It may be helpful to slightly twist the wires as you pull them.
  3. 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 3, Bild 1 von 2 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 3, Bild 2 von 2
    • Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
    • The position of the third bolt is not visible in the second picture.
  4. 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 4, Bild 1 von 1
    • Pull the distributor cap away from the engine and set it aside.
  5. 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 5, Bild 1 von 2 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 5, Bild 2 von 2
    • Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
    • Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
  6. 1998-2002 Honda Accord Distributor Rotor Replacement, Distributor Rotor: Schritt 6, Bild 1 von 2 1998-2002 Honda Accord Distributor Rotor Replacement, Distributor Rotor: Schritt 6, Bild 2 von 2
    • Remove the single #2 Phillips screw securing the distributor rotor to the shaft.
  7. 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 7, Bild 1 von 2 1998-2002 Honda Accord Distributor Rotor Replacement: Schritt 7, Bild 2 von 2
    • Pull the distributor rotor straight off its shaft, being careful not to rotate the shaft as you remove it.
    • When installing the new distributor rotor, press it onto the shaft with the screw holes aligned axially.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
In Step 6, the Phillips screw holding the distributor rotor in place is stuck and it won't turn for me. Any advice on removing that screw, when it is stuck in place? This is on a 1997 Honda Accord LX, non VTEC. Thanks...
CheeseHead1 - Antwort
Get a punch screwdriver. It's a tool that as hit the top it twist. Be care full not to hit to hard. Or if u can fit a angle die grinder cut one line through top part of screw. Use a big flat head screwdriver. Do not cut top of bolt too deep stop right before u get to the bottom of the head of bolt
dbo240 - Antwort
The screw attaching my rotor is missing. 2001 crv do you know the size?
Trish - Antwort
What size is that little screw that holds the distributor rotor?
Francisco Ramirez - Antwort
is there only one screw that holds the rotor to the shaft? I removed the screw but I am unable to take the rotor out. Is there anything holding it in place?
Anupanda - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 54
Insgesamt: 51,560
