Einleitung
Work desks, much like the Inline Systems Desk, are an integral part of a workspace environment and the under desk keyboard trays can wear out or become damaged. This affects the functionality of a person's workspace and negatively impacts user experience and performance. This problem can be resolved and the aim here is to provide a comprehensive guide on how you can easily replace your sliding desk trays and make use of the reusability of a desk to get it back to proper conditions.
Was du brauchst
Remove the eight total 15 mm square socket screws that are securing both of the rails with a screwdriver.
Clean the first railing for the desk tray after taking off its 4 screws, and check for any damage. Repeat the process for the other railing.
Gently align and insert the new tray into the railings once all the screws and railings are back in place.
Test the movement of the keyboard tray by pushing it all the way in and pulling it all the way out to ensure it works normally.
Now that the keyboard tray has been properly replaced, you can use your desk again.
