Zum Hauptinhalt wechseln
ASUS Q524U Hard Drive Replacement
Was du brauchst
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: Schritt 2, Bild 1 von 3 ASUS Q524U Hard Drive Replacement: Schritt 2, Bild 2 von 3 ASUS Q524U Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: Schritt 6, Bild 1 von 2 ASUS Q524U Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 41
Insgesamt: 3,268
