Zum Hauptinhalt wechseln
Acer Iconia W3-810 Screen Replacement
Was du brauchst
  1. Acer Iconia W3-810  Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810  Screen Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810  Screen Replacement, Battery: Schritt 3, Bild 1 von 1
    • Pull the ribbon cord by pushing the clamp on the port toward you with the plastic opening tool.
  4. Acer Iconia W3-810  Screen Replacement: Schritt 4, Bild 1 von 1
    • Move the ribbon cord in order to disconnect the rainbow cord from the battery.
    • Take extra care to not rip the ribbon cord.
  5. Acer Iconia W3-810  Screen Replacement: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool to carefully slide the power cord from its slot by pushing it out from both sides, then remove the cord from its port with your hand.
  6. Acer Iconia W3-810  Screen Replacement: Schritt 6, Bild 1 von 1
    • Pull on the ribbon cord carefully in order to break the seal between the ribbon cord and the battery. Do this until the cord is completely free of the battery.
    • Do not pull the ribbon cord too hard or near the opposite end.
  7. Acer Iconia W3-810  Screen Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to gently wedge out and lift the battery pack from the device.
  8. Acer Iconia W3-810  Screen Replacement: Schritt 8, Bild 1 von 2 Acer Iconia W3-810  Screen Replacement: Schritt 8, Bild 2 von 2
    • Carefully break the bond between the inner tape and the battery using the plastic opening tool. The tape can be found in the middle and either side of the battery.
  9. Acer Iconia W3-810  Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove battery pack
  10. Acer Iconia W3-810  Screen Replacement, Screen: Schritt 10, Bild 1 von 1
    • Disconnect the speaker cord from the motherboard by carefully prying it out with a plastic opening tool.
  11. Acer Iconia W3-810  Screen Replacement: Schritt 11, Bild 1 von 1
    • Loosen the retaining flap using a plastic opening tool, and then pull the ribbon cord from its slot.
  12. Acer Iconia W3-810  Screen Replacement: Schritt 12, Bild 1 von 2 Acer Iconia W3-810  Screen Replacement: Schritt 12, Bild 2 von 2
    • Unscrew the 3mm phillips head screws along the motherboard using a HH0 screwdriver.
  13. Acer Iconia W3-810  Screen Replacement: Schritt 13, Bild 1 von 2 Acer Iconia W3-810  Screen Replacement: Schritt 13, Bild 2 von 2
    • Lift the retaining flap of the ribbon cord connecting the screen circuit board to the motherboard using a plastic opening tool.
    • Then, remove the ribbon cord from its slot using a plastic opening tool.
  14. Acer Iconia W3-810  Screen Replacement: Schritt 14, Bild 1 von 1
    • Unscrew the 3mm phillips head screws from beneath the screen circuit board using the same HHO screwdriver.
  15. Acer Iconia W3-810  Screen Replacement: Schritt 15, Bild 1 von 1
    • Unscrew the 3mm phillips head screws connecting speaker and home button circuit board from main frame using the HHO screwdriver.
  16. Acer Iconia W3-810  Screen Replacement: Schritt 16, Bild 1 von 1
    • Pull ribbon cord from designated slots on screen circuit board.
  17. Acer Iconia W3-810  Screen Replacement: Schritt 17, Bild 1 von 1
    • Unscrew left speaker from frame by moving the ribbon cord out of the way to access the 3mm phillips head screws.
  18. Acer Iconia W3-810  Screen Replacement: Schritt 18, Bild 1 von 1
    • Loosen speaker cord from main back frame by breaking the tape seal using a spudger.
  19. Acer Iconia W3-810  Screen Replacement: Schritt 19, Bild 1 von 1
    • Loosen the main back metal frame from the front casing using a plastic opening tool.
  20. Acer Iconia W3-810  Screen Replacement: Schritt 20, Bild 1 von 1
    • Loosen metal tape from the front panel using a spudger.
  21. Acer Iconia W3-810  Screen Replacement: Schritt 21, Bild 1 von 1
    • detach metal tape from the back of the screen using a spudger.
  22. Acer Iconia W3-810  Screen Replacement: Schritt 22, Bild 1 von 1
    • Remove the screen from the front casing.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Adam Fierce
418 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 18-4, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 36
Insgesamt: 2,261
