Zum Hauptinhalt wechseln
Acer Iconia W3-810 Speaker Replacement
Was du brauchst
  1. Acer Iconia W3-810 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Place the tablet face down on a flat surface with the charger facing toward you.
  2. Acer Iconia W3-810 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to pry the back panel off of the device.
    • Be careful to not use the plastic opening tool near the charging dock or any media ports.
  3. Acer Iconia W3-810 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Lift the retaining flaps fastening the screen ribbon cord to the screen circuit board using a plastic opening tool.
  4. Acer Iconia W3-810 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Pull the ribbon cord out of its slot.
  5. Acer Iconia W3-810 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Lift the retaining flap fastening the ribbon cord.
  6. Acer Iconia W3-810 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the ribbon cord from its slot.
  7. Acer Iconia W3-810 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the Phillips head HH0 3mm screws holding down the right speaker.
  8. Acer Iconia W3-810 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the HHO 3mm screws holding the left speaker.
  9. Acer Iconia W3-810 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift the speakers from the front panel.
  10. Acer Iconia W3-810 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Pull the speakers underneath the headphone cord.
  11. Acer Iconia W3-810 Speaker Replacement: Schritt 11, Bild 1 von 1
    • Use a plastic opening tool to remove the speaker cord from its slot.
  12. Acer Iconia W3-810 Speaker Replacement: Schritt 12, Bild 1 von 1
    • Remove the speakers from the device.
Abschluss
USF Tampa, Team 18-4, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 419
