Zum Hauptinhalt wechseln
Alienware AW610M Scroll Wheel Replacement
Was du brauchst
  1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: Schritt 1, Bild 1 von 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: Schritt 1, Bild 2 von 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: Schritt 1, Bild 3 von 3
    • Turn your mouse over with the scroll wheel facing down.
    • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
    • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
  2. Alienware AW610M Scroll Wheel Replacement: Schritt 2, Bild 1 von 2 Alienware AW610M Scroll Wheel Replacement: Schritt 2, Bild 2 von 2
    • Turn your blowdryer on a low heat setting.
    • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
    • Turn off your blowdryer, unplug the device, and set it aside to cool down.
    • Carefully peel off the stickers, and set aside as well.
  3. Alienware AW610M Scroll Wheel Replacement: Schritt 3, Bild 1 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 3, Bild 2 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 3, Bild 3 von 3
    • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
  4. Alienware AW610M Scroll Wheel Replacement: Schritt 4, Bild 1 von 1
    • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
    • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
  5. Alienware AW610M Scroll Wheel Replacement: Schritt 5, Bild 1 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 5, Bild 2 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 5, Bild 3 von 3
    • Disconnect any wire connections away from the mouse's circuit board.
    • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
    • Locate the scroll wheel placed in the gap of the mouse's backing.
    • My scroll wheel was crooked, most likely causing my issue.
    • Gently lift the scroll wheel mechanism out of the mouse's backing.
  6. Alienware AW610M Scroll Wheel Replacement: Schritt 6, Bild 1 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 6, Bild 2 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the scroll wheel sensor from the mouse backing.
    • Remove the old wheel from the plastic casing, and set it aside.
    • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
  7. Alienware AW610M Scroll Wheel Replacement: Schritt 7, Bild 1 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 7, Bild 2 von 3 Alienware AW610M Scroll Wheel Replacement: Schritt 7, Bild 3 von 3
    • Dip a cotton swab into hydrogen-peroxide.
    • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
    • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
    • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rana Ashour
169 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-71, Briggs Spring 2023 Mitglied von CSU Los Angeles, Team 2-71, Briggs Spring 2023
CSULA-BRIGGS-S23S2G71
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 114
Letzte 30 Tage: 424
Insgesamt: 4,015
