Zum Hauptinhalt wechseln
Anne Pro 2 Keyboard Keycaps Replacement
Was du brauchst
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: Schritt 1, Bild 1 von 1
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: Schritt 2, Bild 1 von 3 Anne Pro 2 Keyboard Keycaps Replacement: Schritt 2, Bild 2 von 3 Anne Pro 2 Keyboard Keycaps Replacement: Schritt 2, Bild 3 von 3
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: Schritt 3, Bild 1 von 2 Anne Pro 2 Keyboard Keycaps Replacement: Schritt 3, Bild 2 von 2
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: Schritt 4, Bild 1 von 1
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: Schritt 5, Bild 1 von 1
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Omar Sukkar
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,951
