Zum Hauptinhalt wechseln
Backpack Base Replacement
Was du brauchst
  1. Backpack Base Replacement, Base: Schritt 1, Bild 1 von 2 Backpack Base Replacement, Base: Schritt 1, Bild 2 von 2
    • Turn the backpack inside out.
  2. Backpack Base Replacement: Schritt 2, Bild 1 von 1
    • Seam rip the binding along the bottom rectangle of the backpack.
    • Discard the ripped panel of burlap.
    • Make sure to set aside the lining fabric before discarding the burlap.
  3. Backpack Base Replacement: Schritt 3, Bild 1 von 3 Backpack Base Replacement: Schritt 3, Bild 2 von 3 Backpack Base Replacement: Schritt 3, Bild 3 von 3
    • Iron the base panel of the polyester lining fabric.
    • Place the lining fabric on top of the desired fabric.
    • Using a ruler and rotary cutter, cut an identical rectangle.
    • Carefully round the corners of your desired fabric rectangle to match the shape of the liner.
    • Use caution when ironing the base panel.
  4. Backpack Base Replacement: Schritt 4, Bild 1 von 3 Backpack Base Replacement: Schritt 4, Bild 2 von 3 Backpack Base Replacement: Schritt 4, Bild 3 von 3
    • Pin the liner and new fabric panel together, so that the 'right sides' of the fabric are facing outwards.
    • Set your machine to the longest stitch length (usually 5 mm), and the loosest thread tension.
    • Not every machine will allow you to adjust the thread tension. If yours allows you to adjust it, set it to zero.
    • Sew the layers together with a 1/4" seam allowance.
  5. Backpack Base Replacement: Schritt 5, Bild 1 von 3 Backpack Base Replacement: Schritt 5, Bild 2 von 3 Backpack Base Replacement: Schritt 5, Bild 3 von 3
    • Pin the lining and new fabric base so that it is centered on the thick side of the backpack.
    • Using a zipper foot, sew the new fabric base and liner to the thick side of the backpack.
    • Be careful to align the corners of the base to the corners of the backpack.
  6. Backpack Base Replacement: Schritt 6, Bild 1 von 3 Backpack Base Replacement: Schritt 6, Bild 2 von 3 Backpack Base Replacement: Schritt 6, Bild 3 von 3
    • Make note of how much larger the fabric base is in comparison to the remaining 3 sides of the backpack.
    • Using a contrasting-colored thread, hand-sew along the corners of the base fabric.
    • Tighten the contrasting threads to bunch up the corners until they fit snug into the corners of the backpack.
    • Pin the remaining 3 sides of the base with to the 3 sides of the backpack.
  7. Backpack Base Replacement: Schritt 7, Bild 1 von 3 Backpack Base Replacement: Schritt 7, Bild 2 von 3 Backpack Base Replacement: Schritt 7, Bild 3 von 3
    • Sew along the remaining three sides.
    • Be extra careful around the corners to avoid any hard creases or folds.
    • Seam-rip the contrasting color thread.
    • Trim down any fabric that exceeds 1/4" seam allowance, particularly around the corners.
  8. Backpack Base Replacement: Schritt 8, Bild 1 von 2 Backpack Base Replacement: Schritt 8, Bild 2 von 2
    • Turn the backpack right side out.
    • Look along the new seam for any of the stitches that hold the lining and base fabric together, and remove them.
    • Pin the binding around the bottom seam, so that it sandwiches the seam allowance.
    • Allow one end of the binding to remain loose.
  9. Backpack Base Replacement: Schritt 9, Bild 1 von 3 Backpack Base Replacement: Schritt 9, Bild 2 von 3 Backpack Base Replacement: Schritt 9, Bild 3 von 3
    • Starting with the pinned end of the binding, carefully sew about 1/10" away from the end of the binding.
    • When you reach the loose end of the binding, connect the end that you already sewed with the loose end.
    • Sew both ends together.
  10. Backpack Base Replacement: Schritt 10, Bild 1 von 3 Backpack Base Replacement: Schritt 10, Bild 2 von 3 Backpack Base Replacement: Schritt 10, Bild 3 von 3
    • Check the inside and out for any flaws or hard creases.
    • Enjoy your newly repaired backpack!
Ziellinie
Sheen Patel
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 63
Insgesamt: 764
