Zum Hauptinhalt wechseln
Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement
Was du brauchst
  1. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a spudger to pry the backing up from the watch.
  2. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the old watch battery from the back carefully with your spudger.
  3. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement: Schritt 3, Bild 1 von 1
    • Replace your old battery with a brand-new battery. Use your spudger to put the brand-new battery into place.
  4. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement: Schritt 4, Bild 1 von 1
    • After replacing the battery, put the backing back on and you should have yourself a working watch.
Ziellinie
Thomias Hughes
159 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 59
Insgesamt: 795
