Zum Hauptinhalt wechseln
Bell and Howell DNV16HDZ Hand Strap Replacement
Was du brauchst
  1. Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: Schritt 1, Bild 1 von 2 Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: Schritt 1, Bild 2 von 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Hand Strap Replacement: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Hand Strap Replacement: Schritt 3, Bild 1 von 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: Schritt 4, Bild 1 von 2 Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: Schritt 4, Bild 2 von 2
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
    • Unscrew the four 40 mm Phillips #0 screws.
    • Add the new hand strap now.
Abschluss
Jerry Hadjah
525 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 208
