Zum Hauptinhalt wechseln
Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement
Was du brauchst
  1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Make sure the diffuser is not plugged into a socket and that there is no water or oil near or in the diffuser before beginning the guide.
    • Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
  2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 2, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 2, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 2, Bild 3 von 3
    • Lift the ceramic top of the oil diffuser.
    • Then lift off the plastic top off the diffuser.
  3. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 3, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 3, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 3, Bild 3 von 3
    • Lift the last plastic lid.
    • You will see a circuit board, and there will be a cord connecting it to the circuit board.
  4. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 4, Bild 1 von 2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 4, Bild 2 von 2
    • Gently unplug the cord from the circuit board.
    • Place the plastic lid somewhere safe on the a flat surface.
  5. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 5, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 5, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the plastic ring and place somewhere safe on a flat surface.
  6. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 6, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 6, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
  7. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 7, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 7, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 7, Bild 3 von 3
    • Gently lift the circuit board onto it's side
    • The white connector plugs the fan into the circuit board.
  8. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 8, Bild 1 von 2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 8, Bild 2 von 2
    • Unplug the white connector.
    • There are four #M1 6 mm Phillips pan head screws holding down the fan.
  9. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 9, Bild 1 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 9, Bild 2 von 3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: Schritt 9, Bild 3 von 3
    • Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
    • Gently lift the fan and place the fan someplace safe on the flat surface.
Abschluss
Muniira Mohamoud
169 Reputation
1 Anleitung geschrieben
York University, Team R-17, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-17, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG17
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 375
