Zum Hauptinhalt wechseln
Briggs and Stratton 675 Series Repair Air Filter Replacement
Was du brauchst
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: Schritt 1, Bild 1 von 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: Schritt 3, Bild 1 von 1
    • Simply remove the air filter with your hands.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 6-31, Amido Winter 2015 Mitglied von Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Mitglieder
15 Anleitungen geschrieben
2 Kommentare
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Antwort
This is a power wash motor water will not come out
hdoggett Doggett - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 50
Letzte 30 Tage: 295
Insgesamt: 19,700
