Zum Hauptinhalt wechseln
Cabinet Magnetic Catch Replacement
Was du brauchst
  1. Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: Schritt 1, Bild 1 von 2 Cabinet Magnetic Catch Replacement, Cabinet Magnet Catch: Schritt 1, Bild 2 von 2
    • Remove two screws from the the old magnetic catch using a Phillips #0 screwdriver.
    • Remove the magnetic catch from the shelf.
    • It is recommended you use a stubby screwdriver since you will be dealing with tight spaces of the cabinet shelf.
  2. Cabinet Magnetic Catch Replacement: Schritt 2, Bild 1 von 1
    • Remove the screws securing the plates to the cabinet doors using a Phillips #0 screwdriver. Remove the plates.
    • Do this on the both sides.
  3. Cabinet Magnetic Catch Replacement: Schritt 3, Bild 1 von 3 Cabinet Magnetic Catch Replacement: Schritt 3, Bild 2 von 3 Cabinet Magnetic Catch Replacement: Schritt 3, Bild 3 von 3
    • Place the new magnetic catch on the center of the shelf cabinet.
    • Ensure it is adjusted carefully by moving its width halfway out of the cabinet and aligned on each side.
  4. Cabinet Magnetic Catch Replacement: Schritt 4, Bild 1 von 1
    • With your graphite pencil, mark the location of the screw holes so you know exactly where you placed it in case you get lost.
  5. Cabinet Magnetic Catch Replacement: Schritt 5, Bild 1 von 1
    • Screw in two 10 mm screws on the new magnetic catch using a Phillips #0 screwdriver to secure it in place.
    • Ensure that you are maintaining alignment of the magnetic catch with the help of Step 4. Otherwise, you will repeat Step 3.
    • You may reuse the old screws from the removal in Step 1 to install the new magnetic catch.
  6. Cabinet Magnetic Catch Replacement: Schritt 6, Bild 1 von 1
    • Close the cabinet and mark down the side of the cabinet door using a graphite pencil.
    • Do this on the other side.
  7. Cabinet Magnetic Catch Replacement: Schritt 7, Bild 1 von 1
    • Screw in one 5mm screw on the new magnetic plate using a Phillips #0 screwdriver to secure it in place on one side of the cabinet door.
    • Ensure that you are maintaining alignment of the magnetic plates with the help of Step 6 and old screw holes.
    • Do this step on the other side with the second 5mm screw.
    • You may reuse the old screws from the removal in Step 2 to install the new magnetic plates.
  8. Cabinet Magnetic Catch Replacement: Schritt 8, Bild 1 von 3 Cabinet Magnetic Catch Replacement: Schritt 8, Bild 2 von 3 Cabinet Magnetic Catch Replacement: Schritt 8, Bild 3 von 3
    • Test the cabinet magnetic catch by closing it.
    • You are finished when the cabinet stays closed after letting your hands go.
Abschluss
You have finished the replacement of cabinet magnetic catch.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brian Hegina
184 Reputation
1 Anleitung geschrieben
York University, Team S2-G10, Melo-Thaiss Summer 2021 Mitglied von York University, Team S2-G10, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G10
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 117
Insgesamt: 3,287
