Zum Hauptinhalt wechseln
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: Schritt 1, Bild 1 von 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: Schritt 1, Bild 2 von 3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: Schritt 1, Bild 3 von 3
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: Schritt 2, Bild 1 von 3 Canon Vixia HF20 Camcorder Strap Replacement: Schritt 2, Bild 2 von 3 Canon Vixia HF20 Camcorder Strap Replacement: Schritt 2, Bild 3 von 3
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: Schritt 3, Bild 1 von 1
    • Once the fit is adjusted, secure by closing the padded strap.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Taylor Morris
225 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 11-6, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-6, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G6
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 536
