Zum Hauptinhalt wechseln
Car and Truck Battery Replacement
Was du brauchst
  1. Car and Truck Battery Replacement, How to Disconnect a Car or Truck Battery: Schritt 1, Bild 1 von 3 Car and Truck Battery Replacement, How to Disconnect a Car or Truck Battery: Schritt 1, Bild 2 von 3 Car and Truck Battery Replacement, How to Disconnect a Car or Truck Battery: Schritt 1, Bild 3 von 3
    • Before you begin, switch the ignition off and remove the key.
    • Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
    • Put on work gloves and safety goggles if you have them available.
    • In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
    • Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
  2. Car and Truck Battery Replacement, Open the hood (bonnet): Schritt 2, Bild 1 von 3 Car and Truck Battery Replacement, Open the hood (bonnet): Schritt 2, Bild 2 von 3 Car and Truck Battery Replacement, Open the hood (bonnet): Schritt 2, Bild 3 von 3
    • Most motor vehicle batteries are located in the engine bay, under the hood (a.k.a. bonnet). If your battery is located elsewhere, skip to Step 5.
    • If you're not sure, simply continue reading.
    • Pull the hood release lever. It's usually located inside the car, near the steering wheel.
  3. Car and Truck Battery Replacement: Schritt 3, Bild 1 von 3 Car and Truck Battery Replacement: Schritt 3, Bild 2 von 3 Car and Truck Battery Replacement: Schritt 3, Bild 3 von 3
    • Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
  4. Car and Truck Battery Replacement: Schritt 4, Bild 1 von 3 Car and Truck Battery Replacement: Schritt 4, Bild 2 von 3 Car and Truck Battery Replacement: Schritt 4, Bild 3 von 3
    • At this point, depending on the vehicle, your hood may raise and support itself automatically.
    • If not, use one hand to hold the hood open temporarily while securing the hood with the prop rod:
    • Lift one end of the prop rod up or out to release it from the front area of the engine bay.
    • Swing the end of the prop rod up and slide it into the cutout on the underside of the hood.
    • Make sure the hood is well secured before you let go with your other hand, or it may fall and injure you.
  5. Car and Truck Battery Replacement: Schritt 5, Bild 1 von 3 Car and Truck Battery Replacement: Schritt 5, Bild 2 von 3 Car and Truck Battery Replacement: Schritt 5, Bild 3 von 3
    • Locate the battery. It's normally rectangular and roughly 8-14" across.
    • The battery may be easy to spot, or it may lie under a plastic cover—usually marked with positive (+) and/or negative (-) symbols.
    • On some models, the battery may be located in the trunk—usually under or behind the trunk lining. Look around or consult your owner's manual.
  6. Car and Truck Battery Replacement: Schritt 6, Bild 1 von 3 Car and Truck Battery Replacement: Schritt 6, Bild 2 von 3 Car and Truck Battery Replacement: Schritt 6, Bild 3 von 3
    • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
    • Always disconnect the negative cable first (before removing the positive cable).
    • The negative terminal may be marked with a minus (-) symbol, or it may be unmarked. The positive terminal is almost always marked with a plus (+) symbol, often in red.
    • If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
  7. Car and Truck Battery Replacement: Schritt 7, Bild 1 von 2 Car and Truck Battery Replacement: Schritt 7, Bild 2 von 2
    • Remove the cable from the negative battery terminal.
    • When connecting the battery, it is advised to roughen up the battery terminals and clean the cable clamp beforehand.
    • Upon reconnecting the battery, make sure to seal the pole connections with an appropriate terminal grease or terminal spray.
  8. Car and Truck Battery Replacement: Schritt 8, Bild 1 von 2 Car and Truck Battery Replacement: Schritt 8, Bild 2 von 2
    • Prevent the cable from making accidental contact with the terminal by pushing it aside and/or wrapping the cable clamp with a dry rag.
  9. Car and Truck Battery Replacement, Battery: Schritt 9, Bild 1 von 2 Car and Truck Battery Replacement, Battery: Schritt 9, Bild 2 von 2
    • Remove the insulating cover from the positive battery terminal (if one is present).
  10. Car and Truck Battery Replacement: Schritt 10, Bild 1 von 2 Car and Truck Battery Replacement: Schritt 10, Bild 2 von 2
    • Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the positive battery terminal.
  11. Car and Truck Battery Replacement: Schritt 11, Bild 1 von 2 Car and Truck Battery Replacement: Schritt 11, Bild 2 von 2
    • Remove the cable from the positive battery terminal.
    • During reassembly, be sure to reconnect and tighten the positive cable clamp first (before the negative cable clamp).
  12. Car and Truck Battery Replacement: Schritt 12, Bild 1 von 1
    • Remove any bolts securing the battery.
  13. Car and Truck Battery Replacement: Schritt 13, Bild 1 von 1
    • Remove any bars or brackets securing the battery.
  14. Car and Truck Battery Replacement: Schritt 14, Bild 1 von 2 Car and Truck Battery Replacement: Schritt 14, Bild 2 von 2
    • Remove the battery.
    • A typical car battery can weigh 50 pounds or more, so lift carefully and get help if needed. Do not drop the battery, as this can release dangerous chemicals.
    • If your battery cable clamps look dirty and/or corroded, clean them up with a wire brush and a mixture of water and baking soda before installing your new battery.
    • To prevent corrosion in the future, coat the new battery's terminals with a little dielectric grease or petroleum jelly.
    • Don't throw the old battery in the trash. Many auto parts stores and service stations will accept old batteries for free safe disposal.
Abschluss
21 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeff Suovanen
429.009 Reputation
259 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
3 Kommentare
You should not just tell people to follow the directions in reverse order for reassembly. There are some steps most mechanics will want you to perform (e.g. applying a compound to the terminals to prevent corrosion) in addition to simply reattaching the cables.
shamino - Antwort
As with most guides on iFixit, reassembly tips are included on the applicable step where appropriate.
Jeff Suovanen -
good for car batery replacement
CanadaVisitorVisa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 55
Letzte 30 Tage: 269
Insgesamt: 11,856
