Zum Hauptinhalt wechseln
Caterpillar S41 Battery Replacement
Was du brauchst
  1. Caterpillar S41 Battery Replacement, Remove the 10 External Screws: Schritt 1, Bild 1 von 2 Caterpillar S41 Battery Replacement, Remove the 10 External Screws: Schritt 1, Bild 2 von 2
    • There are two screws each on the top and the bottom
    • There are three screws each on the left and right.
    • Using your 1.3mm hex bit, remove all 10 screws.
    • All 10 screws are identical and interchangeable, so there is no need to keep them sorted.
  2. Caterpillar S41 Battery Replacement, Open The Seals: Schritt 2, Bild 1 von 3 Caterpillar S41 Battery Replacement, Open The Seals: Schritt 2, Bild 2 von 3 Caterpillar S41 Battery Replacement, Open The Seals: Schritt 2, Bild 3 von 3
    • The Caterpillar CAT S41 has 3 built-in water resistant seals, over the aux port, charging port, and combination Sim and TF/SD Card ports.
    • Loosen all 3 of these port covers.
  3. Caterpillar S41 Battery Replacement, Remove the Sim Card Tray: Schritt 3, Bild 1 von 3 Caterpillar S41 Battery Replacement, Remove the Sim Card Tray: Schritt 3, Bild 2 von 3 Caterpillar S41 Battery Replacement, Remove the Sim Card Tray: Schritt 3, Bild 3 von 3
    • The Sim Card Tray should be removed at this time. Although it is not necessary to remove, it is much more fragile than the frame and is liable to be damaged during the next steps.
    • Using a fingernail from the back side of the phone, pull the sim card tray straight out and away from the phone.
    • The sim card tray or reader inside the phone can be damaged if the tray is forced in upside down. Remember the orientation or refer to these photos here during reassembly.
  4. Caterpillar S41 Battery Replacement, Separate the frame.: Schritt 4, Bild 1 von 3 Caterpillar S41 Battery Replacement, Separate the frame.: Schritt 4, Bild 2 von 3 Caterpillar S41 Battery Replacement, Separate the frame.: Schritt 4, Bild 3 von 3
    • Make sure the phone is face down and flat on a surface to ensure no damage befalls the screen during the next steps.
    • The frame can be separated in any direction, but it is easiest to start in the more-accessible speaker hole, so this guide will assume you start there.
    • Insert an opening pick into the crack between the front half and the back half of the frame.
    • It may take some force to get your pick inserted. These phones are more durable than most and take more force to open than other phones you may have disassembled.
    • Starting on the bottom left corner, work your way around the corner. You should hear a few snaps as the locking clips are disengaged by your opening pick.
    • As the locking clips disengage, they should free up enough space to insert the opening pick in the next section. This holds true throughout the rest of the separation procedure.
  5. Caterpillar S41 Battery Replacement: Schritt 5, Bild 1 von 3 Caterpillar S41 Battery Replacement: Schritt 5, Bild 2 von 3 Caterpillar S41 Battery Replacement: Schritt 5, Bild 3 von 3
    • You'll notice the screw holes in the way. All 10 of the screw holes are connected to the back half of the frame.
    • Try to keep your opening pick between the front (bottom) half of the frame and the screw holes.
    • Skip over the buttons for now and insert your opening pick into the top left corner.
    • Although the buttons should remain in the front half of the frame, they could come out partially or fully during disassembly. Make sure these buttons are present and secure before reassembly.
    • Continue around the corner in a clockwise direction, releasing the locking clips as you go.
  6. Caterpillar S41 Battery Replacement: Schritt 6, Bild 1 von 3 Caterpillar S41 Battery Replacement: Schritt 6, Bild 2 von 3 Caterpillar S41 Battery Replacement: Schritt 6, Bild 3 von 3
    • Continuing clockwise, separate the top right corner of the frame.
    • Skip past the hole where the combination Sim and SD/TF Cards go, and insert your pick on the other side of the hole.
    • Skip past the orange button and insert your pick further down the frame, to finish separating the right side of the frame.
    • Although this button should remain in the front half of the frame, it could come out partially or fully during disassembly. Make sure this button is present and secure before reassembly.
  7. Caterpillar S41 Battery Replacement: Schritt 7, Bild 1 von 2 Caterpillar S41 Battery Replacement: Schritt 7, Bild 2 von 2
    • Continuing clockwise, separate the bottom right corner.
    • Continue all the way to the charger port, making sure to release all of the locking clips along the way.
    • Make sure all locking clips around the phone are released. Due to the force required to separate the frame, some clips may have reengaged while separating other clips.
  8. Caterpillar S41 Battery Replacement, Remove the Back: Schritt 8, Bild 1 von 3 Caterpillar S41 Battery Replacement, Remove the Back: Schritt 8, Bild 2 von 3 Caterpillar S41 Battery Replacement, Remove the Back: Schritt 8, Bild 3 von 3
    • Once all locking clips are disengaged, the back is very easy to remove as it is not held in with any extra adhesive or wires connecting it.
    • Lift the back of the frame straight up. If it does not lift easily, double check around the edges to ensure all locking clips are indeed disengaged.
    • The vibration motor is housed in the back of the frame, and if the back is not removed straight this motor could be damaged.
  9. Caterpillar S41 Battery Replacement, Remove the Screw: Schritt 9, Bild 1 von 2 Caterpillar S41 Battery Replacement, Remove the Screw: Schritt 9, Bild 2 von 2
    • The battery connector is secured with a plate, and the plate is secured with a screw.
    • Using your Torx T4 bit, remove this screw.
  10. Caterpillar S41 Battery Replacement, Remove the Plate: Schritt 10, Bild 1 von 2 Caterpillar S41 Battery Replacement, Remove the Plate: Schritt 10, Bild 2 von 2
    • After the screw is removed, the plate is held in by nothing but friction.
    • Use the tip of your opening pick to lift and remove the plate securing the battery connector in place.
    • This plate is held in firmly, and it will likely attempt to fling itself into the nether. Have a hand ready to block it from flying away, or be prepared to hunt on the ground until you can find it.
  11. Caterpillar S41 Battery Replacement, Disconnect the Battery: Schritt 11, Bild 1 von 3 Caterpillar S41 Battery Replacement, Disconnect the Battery: Schritt 11, Bild 2 von 3 Caterpillar S41 Battery Replacement, Disconnect the Battery: Schritt 11, Bild 3 von 3
    • Using the tip of your spudger, lift and separate the battery connector from the connection on the motherboard.
    • Lightly bend the connector out of the way to ensure it does not inadvertently cause a connection to be reestablished.
  12. Caterpillar S41 Battery Replacement, Loosen the Adhesive: Schritt 12, Bild 1 von 3 Caterpillar S41 Battery Replacement, Loosen the Adhesive: Schritt 12, Bild 2 von 3 Caterpillar S41 Battery Replacement, Loosen the Adhesive: Schritt 12, Bild 3 von 3
    • Using your syringe, inject some 90%+ isopropyl alcohol near the corners of the battery to loosen the adhesive.
    • Give the alcohol a few minutes to soak into and loosen the adhesive securing the battery in place.
  13. Caterpillar S41 Battery Replacement, Cable Attention: Schritt 13, Bild 1 von 2 Caterpillar S41 Battery Replacement, Cable Attention: Schritt 13, Bild 2 von 2
    • Before prying the battery, note this cable.
    • It is highly likely that this cable will stick to the battery. It is still connected within the phone and pulling it up too high can damage the delicate ribbon cable.
  14. Caterpillar S41 Battery Replacement: Schritt 14, Bild 1 von 3 Caterpillar S41 Battery Replacement: Schritt 14, Bild 2 von 3 Caterpillar S41 Battery Replacement: Schritt 14, Bild 3 von 3
    • Using the flat edge of your spudger, begin prying the battery up.
    • There are two points on the right side of the battery that the flat edge of your spudger fits into nicely. Alternate between these two points to avoid too much pressure on any individual point in the battery.
    • Once the battery is lifted high enough, you can switch to the middle of the battery.
    • Pry gently and slowly. If you notice the cable is sticking to the battery, make sure to separate it before lifting the battery too high.
    • If the alcohol had enough time to loosen the adhesive, the battery should come up relatively easily.
  15. Caterpillar S41 Battery Replacement, Cleaning Up: Schritt 15, Bild 1 von 2 Caterpillar S41 Battery Replacement, Cleaning Up: Schritt 15, Bild 2 von 2
    • With the battery removed, check for any punctures or damage to the battery and take appropriate precautions as necessary.
    • Clean up the adhesive residue from the battery compartment, and straighten the previously highlighted cable, to prepare for installing the new battery.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Justin Castle
3.280 Reputation
8 Anleitungen geschrieben
2 Kommentare
Have a nice day. I own a cat s41 phone. How can I get the original front and back case?
Atakan Yüklü - Antwort
Unfortunately I do not know where to buy this part you need. After a search there does not seem to be any reputable vendors selling such.
The best thing I can suggest is buying a broken phone listed as "for parts" or "as/is" or "not working" or etc. If you can inspect the photos to see if the parts you need are in good condition that would work to disassemble and harvest the parts you need. I can see some listed on ebay between $25-$50 USD + shipping, but you may have better luck elsewhere or at marketplaces more local to you.
Justin Castle -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 94
Insgesamt: 2,434
