Zum Hauptinhalt wechseln
Compaq iPAQ Pocket PC 3830 Speaker Replacement
Was du brauchst
  1. Compaq iPAQ Pocket PC 3830 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Compaq iPAQ Pocket PC 3830 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Remove the four 0.8mm Phillips # 00 screws from the back board using the screwdriver from your tool kit.
  2. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 2, Bild 1 von 2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Once the backboard is removed, remove the four screws on the motherboard. Two on top of the motherboard and two on the bottom of the motherboard using the Phillips screwdriver.
  3. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Detach the two pairs of wires, found on the top right of the motherboard, from their combs using the tweezers from the toolkit.
  4. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 4, Bild 1 von 2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 4, Bild 2 von 2
    • In order to get to the speaker, try to free the motherboard by removing all the wires from their combs using the tweezers.
  5. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 5, Bild 1 von 2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Use tweezers to remove wires from combs.
  6. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use your tweezers to free wire from comb in order to free the motherboard.
  7. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Once you have all the wires freed from the combs, you can detach the motherboard just by lifting it out of place.
  8. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 8, Bild 1 von 3 Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 8, Bild 2 von 3 Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the two Phillips #00 screws to get the speaker loose using a Phillips screwdriver. The screws measure 0.3 mm in length.
  9. Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 9, Bild 1 von 2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: Schritt 9, Bild 2 von 2
    • Once the two screws that hold the speaker in place are removed, remove the speaker using tweezers.
Abschluss
Sedina Cavcic
464 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014
USFSM-STEWART-F14S1G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 350
