Zum Hauptinhalt wechseln
Craig CMP801 Battery Replacement
Was du brauchst
  1. Craig CMP801 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Craig CMP801 Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: Schritt 2, Bild 1 von 2 Craig CMP801 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: Schritt 3, Bild 1 von 2 Craig CMP801 Battery Replacement: Schritt 3, Bild 2 von 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Craig CMP801 Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Craig CMP801 Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: Schritt 5, Bild 1 von 3 Craig CMP801 Battery Replacement: Schritt 5, Bild 2 von 3 Craig CMP801 Battery Replacement: Schritt 5, Bild 3 von 3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Duyen
281 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Where do I find a battery cmp749 ???
kourriclay929 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 1,018
