Zum Hauptinhalt wechseln
Creality Ender 3 Bracket Plate of Y-Axis Motor Replacement
Was du brauchst
  1. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement, Bracket Plate of Y-Axis Motor: Schritt 1, Bild 1 von 1
    • Place the bed plate in the middle of your Ender 3. Do this manually by gently pushing it to the middle.
  2. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 2, Bild 1 von 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 2, Bild 2 von 2
    • Or alternatively, place the bed in the center by turning your Ender 3 on.
  3. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 3, Bild 1 von 3 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 3, Bild 2 von 3 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 3, Bild 3 von 3
    • Turn on the printer, and click the button to the screen shown in the photo.
    • Rotate the button clockwise to "Prepare".
    • Rotate the button clockwise to AutoHome. This should set your bedplate to 0 on both X & Y axes.
  4. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 4, Bild 1 von 1
    • Unplug the wire that is connected to the Y motor.
  5. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the two M4*20 screws from the back end of the Y-axis bar using an 8 mm Allen Wrench. The side of the display should be facing you.
  6. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 6, Bild 1 von 1
    • Remove the four M3*6 screws that are attaching the motor to the Y-axis motor using an 8 mm Allen Wrench.
  7. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 7, Bild 1 von 1
    • Buy a new bracket with the same brand (depending on the severity of the bend of the bracket) or straighten the metal on your own.
  8. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 8, Bild 1 von 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 8, Bild 2 von 2
    • If you choose to fix it on your own, slip the bracket in between a workshop bench clamp. Apply enough pressure between two thick blocks of metal to straighten it.
    • Use vise-grips to aid in stabilizing the metal as you force the metal to straighten.
  9. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 9, Bild 1 von 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: Schritt 9, Bild 2 von 2
    • Repeat, Steps 6-11 in reverse to put the bracet back on the Y motor and back on the Ender 3.
    • Turn on Ender 3 to see if you did it correctly. Try to also print something too!
Abschluss
Isabella Bianca Reano
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 69
Insgesamt: 1,812
