Zum Hauptinhalt wechseln
Dell Axim X30 Button Replacement
Was du brauchst
  1. Dell Axim X30 Button Replacement, Buttons: Schritt 1, Bild 1 von 2 Dell Axim X30 Button Replacement, Buttons: Schritt 1, Bild 2 von 2
    • Remove the four rubber feet with your fingers.
  2. Dell Axim X30 Button Replacement: Schritt 2, Bild 1 von 2 Dell Axim X30 Button Replacement: Schritt 2, Bild 2 von 2
    • Insert the nylon spudger into the battery cover release slot to remove the battery from the device.
  3. Dell Axim X30 Button Replacement: Schritt 3, Bild 1 von 1
    • Remove four 12.7mm JIS #0 screws.
  4. Dell Axim X30 Button Replacement: Schritt 4, Bild 1 von 1
    • Remove the back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel will pop off easily.
  5. Dell Axim X30 Button Replacement: Schritt 5, Bild 1 von 3 Dell Axim X30 Button Replacement: Schritt 5, Bild 2 von 3 Dell Axim X30 Button Replacement: Schritt 5, Bild 3 von 3
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Dell Axim X30 Button Replacement: Schritt 6, Bild 1 von 2 Dell Axim X30 Button Replacement: Schritt 6, Bild 2 von 2
    • Remove three 12.7mm JIS #0 screws.
  7. Dell Axim X30 Button Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove motherboard.
  8. Dell Axim X30 Button Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Dell Axim X30 Button Replacement: Schritt 9, Bild 1 von 2 Dell Axim X30 Button Replacement: Schritt 9, Bild 2 von 2
    • Remove black plastic board.
  10. Dell Axim X30 Button Replacement: Schritt 10, Bild 1 von 2 Dell Axim X30 Button Replacement: Schritt 10, Bild 2 von 2
    • Remove grey and green membrane buttons.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team S2-G5, Harley Spring 2018 Mitglied von IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 426
