Zum Hauptinhalt wechseln
DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
Was du brauchst
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: Schritt 1, Bild 1 von 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: Schritt 1, Bild 2 von 2
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 2, Bild 1 von 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 3, Bild 1 von 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 3, Bild 2 von 2
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 4, Bild 1 von 1
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 5, Bild 1 von 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 5, Bild 2 von 2
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 6, Bild 1 von 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 6, Bild 2 von 2
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 7, Bild 1 von 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 7, Bild 2 von 2
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 8, Bild 1 von 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 8, Bild 2 von 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: Schritt 8, Bild 3 von 3
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Theodore Tan
137 Reputation
1 Anleitung geschrieben
Cal Poly, Team 23-4, Green Winter 2015 Mitglied von Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 532
