Zum Hauptinhalt wechseln
Disassembling Motorola Defy XT
Was du brauchst
  1. Disassembling Motorola Defy XT, Disassembling Motorola Defy XT: Schritt 1, Bild 1 von 1
    • Switch off the mobile.
  2. Disassembling Motorola Defy XT: Schritt 2, Bild 1 von 1
    • Unlock the back case before open.
  3. Disassembling Motorola Defy XT: Schritt 3, Bild 1 von 1
    • Remove the battery
    • Remove the memory card
    • Remove the Sim card
  4. Disassembling Motorola Defy XT: Schritt 4, Bild 1 von 2 Disassembling Motorola Defy XT: Schritt 4, Bild 2 von 2
    • Remove 6 screws
    • Tear off a part of label
    • Release the usb cover
  5. Disassembling Motorola Defy XT: Schritt 5, Bild 1 von 1
    • Open the green case part by yours fingernail from left side to the right side with the usb socket
    • Be care of your labels
    • If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
  6. Disassembling Motorola Defy XT: Schritt 6, Bild 1 von 2 Disassembling Motorola Defy XT: Schritt 6, Bild 2 von 2
    • To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
    • 1. Touchscreen adapter
    • 2. Sticker between the touchscreen PCB & mobile PCB
    • Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
  7. Disassembling Motorola Defy XT: Schritt 7, Bild 1 von 3 Disassembling Motorola Defy XT: Schritt 7, Bild 2 von 3 Disassembling Motorola Defy XT: Schritt 7, Bild 3 von 3
    • You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
    • That finger pin is left by the Motorola Support Center in Hong Kong!!
    • You can also clean the camera lens on PCB
  8. Disassembling Motorola Defy XT: Schritt 8, Bild 1 von 1
    • Remember to put all parts back and insert the touchscreen plugs slightly.
    • Put the green case back, make sure all locks is conneted
  9. Disassembling Motorola Defy XT: Schritt 9, Bild 1 von 1
    • You can test the mobile before screw.
    • After insert the memory card, SIM card and battery, switch on the phone
    • Test call in and call out, also check the speaker
    • Open the map Apps to test Wifi and GPS
    • Bluetooth file transfer
    • Camera test and save in sd card
    • Check the sd card files
    • Try to connect with PC
  10. Disassembling Motorola Defy XT: Schritt 10, Bild 1 von 3 Disassembling Motorola Defy XT: Schritt 10, Bild 2 von 3 Disassembling Motorola Defy XT: Schritt 10, Bild 3 von 3
    • If all works, remove the SIM card and battery.
    • Recheck the label is it on the top of the green case
    • Screws up all 6 screws
    • Put back all battery and SIM card
    • Close the back case and lock it
    • Close the USB cover
    • Done
  11. Disassembling Motorola Defy XT: Schritt 11, Bild 1 von 3 Disassembling Motorola Defy XT: Schritt 11, Bild 2 von 3 Disassembling Motorola Defy XT: Schritt 11, Bild 3 von 3
    • If you want to explore what inside of the battery with PCB. Here is the step to follow.
    • Remove the label
    • Remove the black rubber
    • Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
    • Also you can tear PCB by hand
  12. Disassembling Motorola Defy XT: Schritt 12, Bild 1 von 1
    • Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
  13. Disassembling Motorola Defy XT: Schritt 13, Bild 1 von 1
    • ***do not use any metal tools to cut it out!!
  14. Disassembling Motorola Defy XT: Schritt 14, Bild 1 von 1
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 961
