Zum Hauptinhalt wechseln
Disassembling Sony Cyber-Shot DSC-W330 Control Board
Was du brauchst
  1. Disassembling Sony Cyber-Shot DSC-W330 Control Board, Outer Casing: Schritt 1, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board, Outer Casing: Schritt 1, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board, Outer Casing: Schritt 1, Bild 3 von 3
    • Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
    • Note: There are two (2) screws on each side, and five (5) on the bottom edge.
  2. Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 2, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 2, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to carefully pry off the front casing.
    • Be careful to not to force the casing off. Simply move around the entire case separating where needed.
  3. Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 3, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 3, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 3, Bild 3 von 3
    • Flip the camera over 180 degrees and similarly pry off the rear casing.
  4. Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 4, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 4, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 4, Bild 3 von 3
    • Once the outer casings have been removed, the silver side trim should come loose from the camera.
    • Place the camera with the lens facing down. Use the plastic opening tool to pry off the side panel with the USB plug.
    • Note: If you wish to remove the top cover, see the LCD Display Replacement to remove the LCD screen before continuing to Step 5
  5. Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 5, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 5, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 5, Bild 3 von 3
    • Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
    • Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
    • Grasp the top cover and gently remove it from the camera body.
  6. Disassembling Sony Cyber-Shot DSC-W330 Control Board, LCD Display: Schritt 6, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board, LCD Display: Schritt 6, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board, LCD Display: Schritt 6, Bild 3 von 3
    • After the outer casing is removed, lay the device display side up
    • Gently pry the LCD screen from the body of the camera.
    • Be careful not to damage the ribbon cables, they are still attached to the camera.
  7. Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 7, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 7, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board: Schritt 7, Bild 3 von 3
    • Flip the LCD Assembly around the edge of the camera
    • Note: Be careful not to rip the assembly from the camera. It is still attached by the ribbon cables!
    • Use the plastic opening tool to gently pry up the black tab locking the large ribbon cable to the battery housing.
    • Grasp the LCD display with your fingers and gently pull the large ribbon cable out of the connector.
    • The LCD display is now detached from the camera.
  8. Disassembling Sony Cyber-Shot DSC-W330 Control Board, Control Board: Schritt 8, Bild 1 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board, Control Board: Schritt 8, Bild 2 von 3 Disassembling Sony Cyber-Shot DSC-W330 Control Board, Control Board: Schritt 8, Bild 3 von 3
    • Gently pry the tab holding the ribbon cable connecting the cameras control board to the camera sensor and battery housing.
    • The camera control board is now removed and can be replaced if faulty.
Abschluss
Tanner
109 Reputation
1 Anleitung geschrieben
Clemson, Team 13-4, Benson Fall 2013 Mitglied von Clemson, Team 13-4, Benson Fall 2013
CLEM-BENSON-F13S13G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 863
