Zum Hauptinhalt wechseln
Disassembling Sony Cyber-shot DSC-W230 Exterior Case
Was du brauchst
  1. Disassembling Sony Cyber-shot DSC-W230 Exterior Case, Case: Schritt 1, Bild 1 von 1
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Exterior Case: Schritt 2, Bild 1 von 2 Disassembling Sony Cyber-shot DSC-W230 Exterior Case: Schritt 2, Bild 2 von 2
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Exterior Case: Schritt 3, Bild 1 von 3 Disassembling Sony Cyber-shot DSC-W230 Exterior Case: Schritt 3, Bild 2 von 3 Disassembling Sony Cyber-shot DSC-W230 Exterior Case: Schritt 3, Bild 3 von 3
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex
190 Reputation
3 Anleitungen geschrieben
Clemson, Team 2-3, Benson Spring 2012 Mitglied von Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 1,520
