Zum Hauptinhalt wechseln
Drift HD 720 Microphone Replacement
Was du brauchst
  1. Drift HD 720 Microphone Replacement, Battery: Schritt 1, Bild 1 von 2 Drift HD 720 Microphone Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 Microphone Replacement: Schritt 2, Bild 1 von 1
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 Microphone Replacement, Microphone: Schritt 3, Bild 1 von 1
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 Microphone Replacement: Schritt 4, Bild 1 von 1
    • Remove the back case from the camera body.
  5. Drift HD 720 Microphone Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery housing from the camera body.
  6. Drift HD 720 Microphone Replacement: Schritt 6, Bild 1 von 1
    • Remove the microphone first from the rubber housing it is located in, after which you will disconnect the wires connecting the microphone to the motherboard from where they are attached on the motherboard. You will then solder the new speakers wires in the same locations on the motherboard as the wires you just removed.
Abschluss
Baylor, Team 10-16, Williams Fall 2015 Mitglied von Baylor, Team 10-16, Williams Fall 2015
BU-WILLIAMS-F15S10G16
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 352
