Zum Hauptinhalt wechseln
Enagic Water Filter SD501 Platinum Filter Replacement
Was du brauchst
  1. Enagic Water Filter SD501 Platinum Filter Replacement, Filter: Schritt 1, Bild 1 von 1
    • Turn off and unplug the machine before cleaning it.
    • Clean the machine with a damp cloth or paper towel.
    • Make sure nothing dirty will get in the machine during the process.
  2. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 2, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 2, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 2, Bild 3 von 3
    • Open the filter door by pushing the "Push" button.
  3. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 3, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 3, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 3, Bild 3 von 3
    • Turn the ring at the bottom of the filter to the left until you hear a "click".
  4. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 4, Bild 1 von 2 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 4, Bild 2 von 2
    • Remove the ring for now.
  5. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 5, Bild 1 von 2 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 5, Bild 2 von 2
    • Lift up the old filter and discard or recycle appropriately.
    • Some water might be dripping out from the bottom of it. Have a towel ready to clean it up.
  6. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 6, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 6, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 6, Bild 3 von 3
    • Remove the two black rubber rings.
    • They are NOT components of the machine. The new filter you have prepared should come with new ones.
  7. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 7, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 7, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 7, Bild 3 von 3
    • Put your new filter in it.
    • Make sure that the two holes match the two popped-out parts from the filter.
    • The one that is bigger should be on the middle and the smaller one should be on the side.
    • This filter should be the new one that you have prepared and NOT the one that is removed from Step 5.
  8. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 8, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 8, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 8, Bild 3 von 3
    • Put the ring component back in.
    • Turn it to your right until you hear a click.
    • Make sure it is successfully locked in.
  9. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 9, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 9, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 9, Bild 3 von 3
    • Turn the filter back on.
    • Press the "Reset Switch"
    • "FILTER RESET" should be shown on the display.
  10. Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 10, Bild 1 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 10, Bild 2 von 3 Enagic Water Filter SD501 Platinum Filter Replacement: Schritt 10, Bild 3 von 3
    • Attach the filter door.
    • There are three holes to slide the door edge into.
    • And push the "push" button to close it.
Abschluss
To change another filter, simply just follow the instructions once more.
Edwin Ng
181 Reputation
1 Anleitung geschrieben
York University, Team 1-16, O'Regan Fall 2021 Mitglied von York University, Team 1-16, O'Regan Fall 2021
YORK-O'REGAN-F21S1G16
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 62
Insgesamt: 1,742
