Zum Hauptinhalt wechseln
Fujitsu Lifebook Stylistic Q584 Motherboard Replacement
Was du brauchst
  1. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Inner Back Shield: Schritt 4, Bild 1 von 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 6, Bild 1 von 1
  7. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Battery: Schritt 8, Bild 1 von 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 16, Bild 1 von 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 16, Bild 2 von 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Remove the connector with an ESD-safe spudger.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Casey
280 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G1, Henning Spring 2019 Mitglied von IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
step16, that metal clip is supposed to be lifted up, not departed away
net ho - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 1,427
