Zum Hauptinhalt wechseln
Fujitsu Lifebook Stylistic Q584 USB port Replacement
Was du brauchst
  1. Fujitsu Lifebook Stylistic Q584 USB port Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 USB port Replacement, Inner Back Shield: Schritt 4, Bild 1 von 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 5, Bild 1 von 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 6, Bild 1 von 1
  7. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 7, Bild 1 von 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 USB port Replacement, USB port: Schritt 8, Bild 1 von 1
    • Remove 2mm screw with a PH1 screwdriver from USB board
  9. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 9, Bild 1 von 1
    • Disconnect USB periphery ribbon from motherboard
  10. Fujitsu Lifebook Stylistic Q584 USB port Replacement: Schritt 10, Bild 1 von 1
    • Pull USB board up to remove.
Abschluss
Spencer Bacon
410 Reputation
4 Anleitungen geschrieben
Washington State, Team S1-G3, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S1-G3, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G3
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 491
