Zum Hauptinhalt wechseln
G-Wolves Hati Paracord Replacement
Was du brauchst
  1. G-Wolves Hati Paracord Replacement, Mouse Paracord: Schritt 1, Bild 1 von 1
    • Flip your mouse upside down.
  2. G-Wolves Hati Paracord Replacement: Schritt 2, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 2, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 2, Bild 3 von 3
    • Peel off the back right mouse skate.
    • Peel slowly, you don't want to create bends on your skate.
  3. G-Wolves Hati Paracord Replacement: Schritt 3, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 3, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 3, Bild 3 von 3
    • Peel off the back left mouse skate.
  4. G-Wolves Hati Paracord Replacement: Schritt 4, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 4, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 4, Bild 3 von 3
    • Unscrew both of the uncovered screws.
    • 6.4mm Phillips-head screws.
  5. G-Wolves Hati Paracord Replacement: Schritt 5, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 5, Bild 2 von 2
    • Squeeze the mouse under second mouse button until the bottom opens.
  6. G-Wolves Hati Paracord Replacement: Schritt 6, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 6, Bild 2 von 2
    • Pull the bottom piece towards the back of the mouse and upwards to remove it.
    • Pull carefully there is a ribbon cable still connected.
  7. G-Wolves Hati Paracord Replacement: Schritt 7, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 7, Bild 2 von 2
    • Remove the ribbon cable connecting the bottom piece to the upper piece.
  8. G-Wolves Hati Paracord Replacement: Schritt 8, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the following screws:
    • 4.8 mm Phillips-head screws.
  9. G-Wolves Hati Paracord Replacement: Schritt 9, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 9, Bild 2 von 2
    • Flip the bottom piece upside down.
    • Pull the circuit board off without pulling on the cable.
  10. G-Wolves Hati Paracord Replacement: Schritt 10, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 10, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 10, Bild 3 von 3
    • Grab the side ridges and remove the connection.
    • Do not wiggle till slightly removed to not bend pins.
  11. G-Wolves Hati Paracord Replacement: Schritt 11, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 11, Bild 2 von 2
    • Pop off the paracord from the bottom piece.
  12. G-Wolves Hati Paracord Replacement: Schritt 12, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 12, Bild 2 von 2
    • Press in the new paracord.
  13. G-Wolves Hati Paracord Replacement: Schritt 13, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 13, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 13, Bild 3 von 3
    • Rearrange wires to follow the guide ridges.
  14. G-Wolves Hati Paracord Replacement: Schritt 14, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 14, Bild 2 von 2
    • Re-insert the circuit board by lining up the scroll wheel with the front piece and pressing down.
  15. G-Wolves Hati Paracord Replacement: Schritt 15, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 15, Bild 2 von 2
    • Re-insert the screws.
  16. G-Wolves Hati Paracord Replacement: Schritt 16, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 16, Bild 2 von 2
    • Thread the wire through the side opening.
    • Insert the paracord connection.
  17. G-Wolves Hati Paracord Replacement: Schritt 17, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 17, Bild 2 von 2
    • Insert the ribbon cable.
    • Cable is located on the upper mouse piece.
  18. G-Wolves Hati Paracord Replacement: Schritt 18, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 18, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 18, Bild 3 von 3
    • Hover the bottom piece over the upper piece flipped over.
    • Press the bottom piece down and forward till under clip pieces.
    • Press down where skates where removed till there is a click.
  19. G-Wolves Hati Paracord Replacement: Schritt 19, Bild 1 von 2 G-Wolves Hati Paracord Replacement: Schritt 19, Bild 2 von 2
    • Insert the screws.
    • 6.4mm Phillips Head Screws.
  20. G-Wolves Hati Paracord Replacement: Schritt 20, Bild 1 von 3 G-Wolves Hati Paracord Replacement: Schritt 20, Bild 2 von 3 G-Wolves Hati Paracord Replacement: Schritt 20, Bild 3 von 3
    • Press on the skates.
Ziellinie
Ayaan
301 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 5-11, Kershman Fall 2023 Mitglied von CSU Los Angeles, Team 5-11, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G11
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 43
Insgesamt: 197
