Einleitung
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
Was du brauchst
Using a #00 Phillips head screwdriver, remove the following screws:
One 4.6 mm screw
Three 8.2 mm screws
Two 6.1 mm screws
Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
Three 2 mm screw
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Between step 6 and step 7, you skipped a really important step…
