Zum Hauptinhalt wechseln
Home Construction Roofing Tile Replacement
Was du brauchst
  1. Home Construction Roofing Tile  Replacement, Roofing Tile: Schritt 1, Bild 1 von 1
    • Be cautious when climbing the ladder to the roof. Ensure your ladder is secure before climbing.
    • Ensure the damage has not reached the underlayment.
  2. Home Construction Roofing Tile  Replacement: Schritt 2, Bild 1 von 1
    • Depending on where the damaged tile is on the roof, be sure to prime underlayment before adding new roof tile on top.
  3. Home Construction Roofing Tile  Replacement: Schritt 3, Bild 1 von 1
    • Be sure to use affective safety harness when operating in unsafe conditions. Carefully remove the damaged tile(s) using your hammer & crow bar.
  4. Home Construction Roofing Tile  Replacement: Schritt 4, Bild 1 von 1
    • Use roof cement to initially attach the tiles to each other & to add security to the underlayment.
    • Be sure to wear the proper gear, such as: shoes, hats, & breathable clothing.
  5. Home Construction Roofing Tile  Replacement: Schritt 5, Bild 1 von 3 Home Construction Roofing Tile  Replacement: Schritt 5, Bild 2 von 3 Home Construction Roofing Tile  Replacement: Schritt 5, Bild 3 von 3
    • Secure the tile to the cement by pressing down on the tile using the handle of the hammer.
    • Use the handle of the hammer to maneuver into correct position.
    • As seen in the bottom of the picture, using too much cement can leak out from both sides of the tile. Be sure to keep it as hidden underneath the tile as possible.
    • Safety first. Don't forget to wear a harness and be sure to understand handling of cement take.
  6. Home Construction Roofing Tile  Replacement: Schritt 6, Bild 1 von 1
    • Walk carefully on the tiles that are already set into place.
  7. Home Construction Roofing Tile  Replacement: Schritt 7, Bild 1 von 1
    • Using the backside of the hammer to slide up the piece overlapping the broken one and using a drill to unscrew any screws (which won't be necessary if you're using roof cement). Replace the tile with the new one and glue in place.
  8. Home Construction Roofing Tile  Replacement: Schritt 8, Bild 1 von 1
    • This is an initial point of view for replacing a single broken tile. You can see the application of roof cement in the crevice of the tile.
Abschluss
To reassemble your device, follow these instructions in reverse order. Number one thing of importance is your safety, my goal is for this guide to give you a general idea of the steps it takes to construct/repair/replace a tile roof.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jonathan Fuentes
187 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 530
