Zum Hauptinhalt wechseln
Household Primo water dispenser not charging
Einführungsvideo
  1. Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: Schritt 1, Bild 1 von 3 Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: Schritt 1, Bild 2 von 3 Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: Schritt 1, Bild 3 von 3
    • Insert wisdom here.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I wish I had found this video before I had bought this particular pump dispenser. On the other hand, maybe my son can actually fix it because he likes messing with things just like this. Thank you, goasfaras, for that very good video. It was very instructive. If you do any more in the future though, pay attention to your voice volume, the direction in which your voice is going, and the pitch of your voice. There were times during the video when I couldn't hear anything that you were saying and I had to guess. I'm hoping that I understood your message correctly in that you said there was no way to fix the pump without using better pieces than what was found on the little board.
Ted Cassetta - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 19
Letzte 30 Tage: 107
Insgesamt: 5,271
