Zum Hauptinhalt wechseln
How To Remove Hardened Masking Tape From Car Paint
Was du brauchst
  1. How To Remove Hardened Masking Tape From Car Paint, How To Remove Hardened Masking Tape From Car Paint: Schritt 1, Bild 1 von 1
    • Goo Gone can be harmful to skin after prolonged exposure so be sure to have your gloves on during this entire process.
    • Spray the paper towel 2 times with the Goo Gone.
    • Be sure to turn the nozzle into the "on" position.
  2. How To Remove Hardened Masking Tape From Car Paint: Schritt 2, Bild 1 von 1
    • Press the wet paper towel against the hardened tape for about 30 seconds.
    • This will soften the tape.
  3. How To Remove Hardened Masking Tape From Car Paint: Schritt 3, Bild 1 von 2 How To Remove Hardened Masking Tape From Car Paint: Schritt 3, Bild 2 von 2
    • Aggressively scrub the tape for about 10 seconds.
  4. How To Remove Hardened Masking Tape From Car Paint: Schritt 4, Bild 1 von 2 How To Remove Hardened Masking Tape From Car Paint: Schritt 4, Bild 2 von 2
    • Repeat steps 2 and 3 until all of the adhesive residue has been removed.
Abschluss
Now that you have successfully removed the tape for your car, it is recommended that you wash your car to get rid of the Goo Gone remnants. Who doesn't love a clean car, anyway?
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Jami Hahn
344 Reputation
1 Anleitung geschrieben
Cal Poly, Team 12-4, Green Winter 2015 Mitglied von Cal Poly, Team 12-4, Green Winter 2015
CPSU-GREEN-W15S12G4
5 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
This masking tape has been on the side of this old VW for years will googone still take off several layers of it ?
Randy Verburg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 110
Insgesamt: 35,976
