Zum Hauptinhalt wechseln
How To Remove Rust From Old Tools
Was du brauchst
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: Schritt 1, Bild 1 von 2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: Schritt 1, Bild 2 von 2
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: Schritt 2, Bild 1 von 2 How To Remove Rust From Old Tools: Schritt 2, Bild 2 von 2
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: Schritt 3, Bild 1 von 3 How To Remove Rust From Old Tools: Schritt 3, Bild 2 von 3 How To Remove Rust From Old Tools: Schritt 3, Bild 3 von 3
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: Schritt 4, Bild 1 von 3 How To Remove Rust From Old Tools: Schritt 4, Bild 2 von 3 How To Remove Rust From Old Tools: Schritt 4, Bild 3 von 3
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: Schritt 5, Bild 1 von 1
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Geoff Wacker
90.075 Reputation
89 Anleitungen geschrieben
2 Kommentare
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Antwort
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 131
Insgesamt: 4,484
