Zum Hauptinhalt wechseln
How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: Schritt 1, Bild 1 von 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: Schritt 1, Bild 2 von 2
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: Schritt 2, Bild 1 von 3 How to Change Broken Buttons on your Lexus Key Fob: Schritt 2, Bild 2 von 3 How to Change Broken Buttons on your Lexus Key Fob: Schritt 2, Bild 3 von 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: Schritt 3, Bild 1 von 3 How to Change Broken Buttons on your Lexus Key Fob: Schritt 3, Bild 2 von 3 How to Change Broken Buttons on your Lexus Key Fob: Schritt 3, Bild 3 von 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: Schritt 4, Bild 1 von 2 How to Change Broken Buttons on your Lexus Key Fob: Schritt 4, Bild 2 von 2
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: Schritt 5, Bild 1 von 3 How to Change Broken Buttons on your Lexus Key Fob: Schritt 5, Bild 2 von 3 How to Change Broken Buttons on your Lexus Key Fob: Schritt 5, Bild 3 von 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
Abschluss
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Michael Tan
587 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 30-3, Green Spring 2015 Mitglied von Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
useless guide
Davide - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 50
Insgesamt: 6,218
