Zum Hauptinhalt wechseln
How to Fix A Rusted Hitch
Was du brauchst
  1. How to Fix A Rusted Hitch, How to Fix A Rusted Hitch: Schritt 1, Bild 1 von 1
    • This is the before picture of the rusted hitch.
  2. How to Fix A Rusted Hitch: Schritt 2, Bild 1 von 1
    • Apply the wire brush on any part of the hitch in order to brush off any excess rust or rust flakes.
  3. How to Fix A Rusted Hitch: Schritt 3, Bild 1 von 2 How to Fix A Rusted Hitch: Schritt 3, Bild 2 von 2
    • Use the small paint brush to apply a coat of naval jelly over the rusted area.
    • Allow to sit for approximately ten minutes.
    • Remember to use caution/gloves when handling the naval jelly.
  4. How to Fix A Rusted Hitch: Schritt 4, Bild 1 von 1
    • Dip the paper towel in a bowl of lukewarm water to get the paper towel damp.
  5. How to Fix A Rusted Hitch: Schritt 5, Bild 1 von 1
    • Take the wet paper towel and wipe off the naval jelly on the hitch.
  6. How to Fix A Rusted Hitch: Schritt 6, Bild 1 von 1
    • Apply a protective layer of fluid film to the treated area.
    • Spray approximately 4-6 inches away from the hitch.
  7. How to Fix A Rusted Hitch: Schritt 7, Bild 1 von 1
    • Allow the fluid film to sit for about 5 minutes.
    • You should start to see bubbling in this process.
  8. How to Fix A Rusted Hitch: Schritt 8, Bild 1 von 1
    • This is the finished, rust-free, product.
Abschluss
This procedure cannot be performed again immediately after the rust is taken off. Repeat these steps when rust develops over time.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kiley Strickland
184 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019
USFSM-STEWART-S19S1G1
18 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 53
Insgesamt: 1,411
