Zum Hauptinhalt wechseln
How to Fix Broken Pottery Using Kintsugi
Was du brauchst
  1. How to Fix Broken Pottery Using Kintsugi, How to Fix Broken Pottery Using Kintsugi: Schritt 1, Bild 1 von 1
    • Clean the pottery with water and dry it with a towel.
  2. How to Fix Broken Pottery Using Kintsugi: Schritt 2, Bild 1 von 1
    • Combine the resin and the hardener in a container creating the epoxy.
    • Add 3 drops of each (resin and hardener).
  3. How to Fix Broken Pottery Using Kintsugi: Schritt 3, Bild 1 von 1
    • Use a craft stick to add the gold powder (Mica Powder) into the combination of resin and hardener.
    • Use a pinch of the Mica Powder.
  4. How to Fix Broken Pottery Using Kintsugi: Schritt 4, Bild 1 von 1
    • Stir the combination (epoxy and Mica Powder) with a tooth pick.
    • Make sure to not leave the combination (epoxy and Mica Powder) too long without stirring because it will begin to harden.
  5. How to Fix Broken Pottery Using Kintsugi: Schritt 5, Bild 1 von 1
    • Apply the combination (epoxy and Mica Powder) on one piece of the pottery.
    • Make sure one of the broken pieces is fully covered with the combination before placing the pieces together.
  6. How to Fix Broken Pottery Using Kintsugi: Schritt 6, Bild 1 von 1
    • Combine both pieces of pottery and allow the epoxy to dry for 5 minutes.
Ziellinie
Hannah Rickman
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 189
