Zum Hauptinhalt wechseln
How to Fix a Broken Zipper
Was du brauchst
  1. How to Fix a Broken Zipper, How to Fix a Broken Zipper: Schritt 1, Bild 1 von 3 How to Fix a Broken Zipper, How to Fix a Broken Zipper: Schritt 1, Bild 2 von 3 How to Fix a Broken Zipper, How to Fix a Broken Zipper: Schritt 1, Bild 3 von 3
    • Take the needle nose pliers and remove the metal or plastic stopper at the end of the zipper.
    • Zip the zipper all the way down to the last set of teeth.
  2. How to Fix a Broken Zipper: Schritt 2, Bild 1 von 3 How to Fix a Broken Zipper: Schritt 2, Bild 2 von 3 How to Fix a Broken Zipper: Schritt 2, Bild 3 von 3
    • Align both sides of the zipper evenly and slip the zipper back on track.
  3. How to Fix a Broken Zipper: Schritt 3, Bild 1 von 3 How to Fix a Broken Zipper: Schritt 3, Bild 2 von 3 How to Fix a Broken Zipper: Schritt 3, Bild 3 von 3
    • Start zipping up the zipper to make sure it has been aligned properly.
  4. How to Fix a Broken Zipper: Schritt 4, Bild 1 von 3 How to Fix a Broken Zipper: Schritt 4, Bild 2 von 3 How to Fix a Broken Zipper: Schritt 4, Bild 3 von 3
    • Thread the needle.
    • Sew up the area where the metal or plastic stopper used to reside.
  5. How to Fix a Broken Zipper: Schritt 5, Bild 1 von 3 How to Fix a Broken Zipper: Schritt 5, Bild 2 von 3 How to Fix a Broken Zipper: Schritt 5, Bild 3 von 3
    • Tie off what has been sewn by making a knot in the thread.
  6. How to Fix a Broken Zipper: Schritt 6, Bild 1 von 2 How to Fix a Broken Zipper: Schritt 6, Bild 2 von 2
    • Take the scissors and cut off the excess thread. Get as close to the knot as you can without cutting it off.
  7. How to Fix a Broken Zipper: Schritt 7, Bild 1 von 3 How to Fix a Broken Zipper: Schritt 7, Bild 2 von 3 How to Fix a Broken Zipper: Schritt 7, Bild 3 von 3
    • Zip up the garment to make sure everything is working properly.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Not helpful. Suppose if the slider part broke and is now now. Now what?
Walter Nagel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 81
Insgesamt: 4,355
