Zum Hauptinhalt wechseln
How to Fix a Crooked Cabinet
Was du brauchst
  1. How to Fix a Crooked Cabinet, Examine the Issue: Schritt 1, Bild 1 von 3 How to Fix a Crooked Cabinet, Examine the Issue: Schritt 1, Bild 2 von 3 How to Fix a Crooked Cabinet, Examine the Issue: Schritt 1, Bild 3 von 3
    • Examine which door needs to be adjusted and to what extent.
  2. How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: Schritt 2, Bild 1 von 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: Schritt 2, Bild 2 von 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: Schritt 2, Bild 3 von 3
    • Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
    • Tighten the screws to adjust accordingly.
  3. How to Fix a Crooked Cabinet, Repeat with the Top Screws: Schritt 3, Bild 1 von 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: Schritt 3, Bild 2 von 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: Schritt 3, Bild 3 von 3
    • Repeat Step 2 with the screws at the top.
  4. How to Fix a Crooked Cabinet, Adjust to Gap: Schritt 4, Bild 1 von 1
    • The gap should be even from top to bottom, ensure that it is and hold the cabinet in place to adjust if it is not.
  5. How to Fix a Crooked Cabinet, Feel Accomplished: Schritt 5, Bild 1 von 2 How to Fix a Crooked Cabinet, Feel Accomplished: Schritt 5, Bild 2 von 2
    • You've done it! As long as the gap is even, your results should be just like this.
    • Great job!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Elmore Smith
148 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 85
Insgesamt: 963
