Zum Hauptinhalt wechseln
How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock
Was du brauchst
  1. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 1, Bild 1 von 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock, How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 1, Bild 2 von 2
    • Make sure the lock is in the unlock position when you start.
    • Use a Philips #1 screwdriver to remove the two 8 mm screws from the left and right sides of the lock.
  2. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 2, Bild 1 von 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 2, Bild 2 von 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 2, Bild 3 von 3
    • Lift the faceplate from the lock.
    • Locate the battery pack stationed at the top of the lock and the programming button at the center of the lock.
  3. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 3, Bild 1 von 1
    • Pull the battery pack up and off to remove it from the lock housing.
  4. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 4, Bild 1 von 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 4, Bild 2 von 2
    • Re-insert the battery pack while holding down the programming button.
    • Ensure the battery pack is fully inserted by pushing it down.
  5. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 5, Bild 1 von 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 5, Bild 2 von 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 5, Bild 3 von 3
    • Release the programming button after the indicator light turns red then green.
    • Repeat steps 3 through 5 if the light does not turn green.
  6. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 6, Bild 1 von 2 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 6, Bild 2 von 2
    • Press the program button again to allow the Smartlock to re-calibrate and reprogram itself.
    • The lock will lock and unlock a few times to calibrate and will remain in the lock position when the calibration is complete.
  7. How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 7, Bild 1 von 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 7, Bild 2 von 3 How to Fix a Jammed Weiser SmartCode 10 Touchscreen Door Lock: Schritt 7, Bild 3 von 3
    • To reassemble your lock, reseat the faceplate on the lock.
    • Twist the lock switch until it aligns with the bolt mechanism and the faceplate sits flush against the lock.
    • Use the Phillips #1 screwdriver to secure the two 8 mm screws back into place to conclude the fix.
Abschluss
Your lock will not jam anymore!
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team 1-21, O'Regan Fall 2021 Mitglied von York University, Team 1-21, O'Regan Fall 2021
YORK-O'REGAN-F21S1G21
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 57
Letzte 30 Tage: 294
Insgesamt: 14,209
