Zum Hauptinhalt wechseln
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
Was du brauchst
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 1, Bild 1 von 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 1, Bild 2 von 2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 2, Bild 1 von 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 2, Bild 2 von 2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 3, Bild 1 von 1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 4, Bild 1 von 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 4, Bild 2 von 2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 5, Bild 1 von 1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 6, Bild 1 von 1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 7, Bild 1 von 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: Schritt 7, Bild 2 von 2
    • Tighten the two screws using a JIS #00 screwdriver.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 1,113
