Zum Hauptinhalt wechseln
How to Fix a Small Ceramic Statue
Was du brauchst
  1. How to Fix a Small Ceramic Statue, How to Fix a Small Ceramic Statue: Schritt 1, Bild 1 von 1
    • Gather all the pieces and dust them off using the toothbrush. This way there is no stray shards left on the pieces.
  2. How to Fix a Small Ceramic Statue: Schritt 2, Bild 1 von 1
    • Lay all the pieces on a towel or clean surface, aligned with where they belong. This way it is easy to find what you need in a timely manner.
    • This step is not required but recommended to keep all of the broken pieces organized.
  3. How to Fix a Small Ceramic Statue: Schritt 3, Bild 1 von 2 How to Fix a Small Ceramic Statue: Schritt 3, Bild 2 von 2
    • Using the largest piece as the base for the repair, start gluing the pieces back where they belong. Make sure to not overuse the glue, as it can cause issues later.
    • Follow the instructions for the super glue you are using, dampening areas with water if needed.
  4. How to Fix a Small Ceramic Statue: Schritt 4, Bild 1 von 1
    • As you glue each piece make sure to hold it in place until it solidifies enough to hold everything in place, then glue on the next piece.
    • This step can vary in time. The glue I used required being held in place for a few minutes.
  5. How to Fix a Small Ceramic Statue: Schritt 5, Bild 1 von 1
    • After you glue it back together, allow it to dry. This way the glue has time to set in place and harden.
    • Make sure your ceramic piece is somewhere stable and dry. If it is not stable it could fall and break again. If the room is not dry the glue could have issues drying properly.
  6. How to Fix a Small Ceramic Statue: Schritt 6, Bild 1 von 1
    • Finally, lightly sand and paint the areas you glued.
Ziellinie
Trenton Gilbert
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 61
Insgesamt: 1,156
