Zum Hauptinhalt wechseln
How to Fix a Wobbly Hydraulic Barber Chair
Was du brauchst
  1. How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: Schritt 1, Bild 1 von 2 How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: Schritt 1, Bild 2 von 2
    • The issue with the barber chair is located at the base, where the screws have come loose.
  2. How to Fix a Wobbly Hydraulic Barber Chair: Schritt 2, Bild 1 von 2 How to Fix a Wobbly Hydraulic Barber Chair: Schritt 2, Bild 2 von 2
    • Use your foot to repeatedly pump the hydraulic height-adjustment pedal under the chair until the chair reaches max height.
    • While holding the pedal down with your foot, grab both arm rests and pull the chair upwards.
  3. How to Fix a Wobbly Hydraulic Barber Chair: Schritt 3, Bild 1 von 1
    • Lift the base-ring off the base to reveal the holes for the screws.
  4. How to Fix a Wobbly Hydraulic Barber Chair: Schritt 4, Bild 1 von 1
    • Place a screw with a washer attached into a hole and tighten it with a 7/32" hex bit.
    • Repeat this process for the other 5 screws and washers.
  5. How to Fix a Wobbly Hydraulic Barber Chair: Schritt 5, Bild 1 von 1
    • Align the bottom of the seat with the top of the pole, and gently put it back into position.
  6. How to Fix a Wobbly Hydraulic Barber Chair: Schritt 6, Bild 1 von 1
    • Make sure the seat is properly fitted onto the pole by gently pushing down on the seat.
    • Check the stability of the pole by gently shaking the chair.
Abschluss
Gaurav Tiwari
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G28, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G28, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G28
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 56
Insgesamt: 3,619
