Zum Hauptinhalt wechseln
How to Fix an Overheating Desktop Computer
Was du brauchst
  1. How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: Schritt 1, Bild 1 von 3 How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: Schritt 1, Bild 2 von 3 How to Fix an Overheating Desktop Computer, How to Fix an Overheating Desktop Computer: Schritt 1, Bild 3 von 3
    • Remove the screws from the side tempered glass panel using your hands.
    • Remove the front panel cover by applying a pulling force to the grip.
    • The position of the grip varies in case designs.
  2. How to Fix an Overheating Desktop Computer: Schritt 2, Bild 1 von 1
    • Clean the front panel dust filter using a tissue or a cloth.
    • This step assures the internal components can easily access fresh air without dust accretion.
  3. How to Fix an Overheating Desktop Computer: Schritt 3, Bild 1 von 3 How to Fix an Overheating Desktop Computer: Schritt 3, Bild 2 von 3 How to Fix an Overheating Desktop Computer: Schritt 3, Bild 3 von 3
    • Remove the screws that are connecting the CPU cooler and wires to the motherboard.
    • This applies to most AMD and Intel CPU brackets.
    • If you are still not sure about how to remove the cooler, refer to your motherboard’s manual guide for more information.
  4. How to Fix an Overheating Desktop Computer: Schritt 4, Bild 1 von 1
    • Remove the CPU from the motherboard by raising the retention arm. Lay the CPU carefully on a soft surface to avoid damaging him by deforming some pins.
  5. How to Fix an Overheating Desktop Computer: Schritt 5, Bild 1 von 2 How to Fix an Overheating Desktop Computer: Schritt 5, Bild 2 von 2
    • Use a tissue to gently clean off the leftover thermal compound.
    • Apply a small amount of thermal paste (or liquid metal) to the surface of the CPU.
    • You can refer to the Wie trage ich Wärmeleitpaste am besten auf guide for more information.
  6. How to Fix an Overheating Desktop Computer: Schritt 6, Bild 1 von 3 How to Fix an Overheating Desktop Computer: Schritt 6, Bild 2 von 3 How to Fix an Overheating Desktop Computer: Schritt 6, Bild 3 von 3
    • Reattach the screws that connect the CPU cooler and wires to the motherboard.
  7. How to Fix an Overheating Desktop Computer: Schritt 7, Bild 1 von 3 How to Fix an Overheating Desktop Computer: Schritt 7, Bild 2 von 3 How to Fix an Overheating Desktop Computer: Schritt 7, Bild 3 von 3
    • Mount two 120 mm type case fans on top of the case as an addition to exhausting hot air. You need at least four screws (two for each fan mounting diagonally) to mount the fans. (I recommend eight screws.)
    • This process improves the airflow inside the case because the heat generated by the CPU and the GPU will dissipate faster.
  8. How to Fix an Overheating Desktop Computer: Schritt 8, Bild 1 von 1
    • Replace the screws from the side tempered glass panel using your hands.
    • Reattach the front panel cover.
  9. How to Fix an Overheating Desktop Computer: Schritt 9, Bild 1 von 2 How to Fix an Overheating Desktop Computer: Schritt 9, Bild 2 von 2
    • Run the system and check for its cooling performance. When your system is on heavy workload, you can increase the fan speed of either the CPU or GPU for better heat dissipation.
    • Check the temperature of your CPU and increase the cooler fan speed by using SpeedFan.
    • Check your GPU temperature and increase the fan speed by using MSI Afterburner.
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Quan Nguyen
250 Reputation
1 Anleitung geschrieben
York University, Team S1-G21, O'Regan Summer 2020 Mitglied von York University, Team S1-G21, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G21
1 Mitglied
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 55
Insgesamt: 3,934
