Zum Hauptinhalt wechseln
How to Get Dents Out of Wood
Was du brauchst
  1. How to Get Dents Out of Wood, How to Get Dents Out of Wood: Schritt 1, Bild 1 von 3 How to Get Dents Out of Wood, How to Get Dents Out of Wood: Schritt 1, Bild 2 von 3 How to Get Dents Out of Wood, How to Get Dents Out of Wood: Schritt 1, Bild 3 von 3
    • Fill a medium-sized bowl with room-temperature water.
    • Dip a hand towel into the bowl of water.
    • Wring the hand towel out a bit until it is damp rather than dripping wet.
  2. How to Get Dents Out of Wood: Schritt 2, Bild 1 von 2 How to Get Dents Out of Wood: Schritt 2, Bild 2 von 2
    • In the wood surface, find the dent you wish to remove.
    • Place the damp hand towel over the dented area as flat as possible.
  3. How to Get Dents Out of Wood: Schritt 3, Bild 1 von 2 How to Get Dents Out of Wood: Schritt 3, Bild 2 von 2
    • Set your flat iron to its highest setting.
    • Do NOT touch the metal part of the flat iron while it is on.
  4. How to Get Dents Out of Wood: Schritt 4, Bild 1 von 3 How to Get Dents Out of Wood: Schritt 4, Bild 2 von 3 How to Get Dents Out of Wood: Schritt 4, Bild 3 von 3
    • Firmly press the flat iron down on the damp hand towel.
    • While pressing down, move the iron in circular or back and forth motions.
  5. How to Get Dents Out of Wood: Schritt 5, Bild 1 von 1
    • Continue the circular or back and forth motions until the hand towel is dry.
  6. How to Get Dents Out of Wood: Schritt 6, Bild 1 von 1
    • Repeat steps 1-5 until the dent is gone.
    • Turn off the flat iron after finishing.
    • Be sure to allow time for the iron to cool down after turning it off. Do NOT touch the metal or place it face down during this time.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UC Davis, Team 1-12, Morris Winter 2023 Mitglied von UC Davis, Team 1-12, Morris Winter 2023
UCD-MORRIS-W23S1G12
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 9
Letzte 30 Tage: 51
Insgesamt: 373
