Zum Hauptinhalt wechseln
How to Install A Car Camera Into Cigar Jack
  1. How to Install A Car Camera Into Cigar Jack, Set up the camera at your computer desk.: Schritt 1, Bild 1 von 1
    • Connect up the car camera to your PC via a USB cable.
    • Browse through the settings menu and key in any required information. E.g Time & Date Stamp, Voice Recording(On/Off)
    • Insert a Class 10 SD Card and format the SD Card using the device's setting menu.
    • Try recording a video at your computer desk and test the playback function
  2. How to Install A Car Camera Into Cigar Jack, Attach the camera to your windscreen: Schritt 2, Bild 1 von 1
    • Plunge the camera with the suction cup to your preferred point.
    • Tip: Wet the windscreen with some clean water before plunging in the suction cup for a stronger hold.
  3. How to Install A Car Camera Into Cigar Jack, Tuck the USB Cable into overhead fabric: Schritt 3, Bild 1 von 1
    • Start tucking the USB Cable into the gap above the passenger seat.
    • Align the cable between the gap and secure the cable in place by pushing in the wires using your four fingers.
  4. How to Install A Car Camera Into Cigar Jack, Remove the side trunking slightly: Schritt 4, Bild 1 von 1
    • The side door trunking can be easily detached by giving it a firm nudge.
    • Hide the cable beneath the trunking leaving the free end nearer to the passenger seat as depicted in the picture.
  5. How to Install A Car Camera Into Cigar Jack, Run the cable along the rubber sleeve by the side door: Schritt 5, Bild 1 von 1
    • Push the cable into the rubber sleeve using your thumb
    • Keep your thumb in the sleeve and run the cable downwards until you reach the glove compartment area.
  6. How to Install A Car Camera Into Cigar Jack, Hook the cables onto any crevices you can find underneath the glove box: Schritt 6, Bild 1 von 1
    • Use some duct tape to hold the cables in place if there are no crevices underneath your glove compartment.
    • Hang on there, you're almost done.
  7. How to Install A Car Camera Into Cigar Jack, Connect up the USB cable into the Cigar Jack Port: Schritt 7, Bild 1 von 1
    • Plug in the USB convertor into the Cigar Jack Port.
    • Connect up the USB cable of the car camera into the port.
    • Start your engine if you haven't done so, car camera should switch on automatically upon detecting power from the car.
  8. How to Install A Car Camera Into Cigar Jack, You are done.: Schritt 8, Bild 1 von 1
    • Ensure the camera is powered correctly, look for a charging indicator icon on your car camera device.
    • Make sure there is a red rounded icon that indicates "Record in Progress" before you drive off everyday.
    • You are done, enjoy the reassuring driving experience and be safe.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Alden
281 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 59
Insgesamt: 2,653
