Zum Hauptinhalt wechseln
How to Install a 2.5" SSD Into a Silicone Enclosure
  1. How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: Schritt 1, Bild 1 von 2 How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: Schritt 1, Bild 2 von 2
    • Before you insert the new hard drive, note the orientation of the SATA connectors embedded in the enclosure:
    • The wide power SATA port
    • The narrower data SATA port
  2. How to Install a 2.5" SSD Into a Silicone Enclosure: Schritt 2, Bild 1 von 3 How to Install a 2.5" SSD Into a Silicone Enclosure: Schritt 2, Bild 2 von 3 How to Install a 2.5" SSD Into a Silicone Enclosure: Schritt 2, Bild 3 von 3
    • Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's.
    • Slide the drive into the enclosure's opening.
    • Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
  3. How to Install a 2.5" SSD Into a Silicone Enclosure: Schritt 3, Bild 1 von 3 How to Install a 2.5" SSD Into a Silicone Enclosure: Schritt 3, Bild 2 von 3 How to Install a 2.5" SSD Into a Silicone Enclosure: Schritt 3, Bild 3 von 3
    • Stretch the remaining enclosure corners over the drive so that the silicone cover encapsulates the drive.
Abschluss
Your drive is ready to be used!
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Arthur Shi
255.299 Reputation
529 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.524 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 1,485
