Zum Hauptinhalt wechseln
How to Reattach the Head of a Mailbox to the Base
Was du brauchst
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: Schritt 1, Bild 1 von 2 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: Schritt 1, Bild 2 von 2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: Schritt 2, Bild 1 von 2 How to Reattach the Head of a Mailbox to the Base: Schritt 2, Bild 2 von 2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: Schritt 3, Bild 1 von 3 How to Reattach the Head of a Mailbox to the Base: Schritt 3, Bild 2 von 3 How to Reattach the Head of a Mailbox to the Base: Schritt 3, Bild 3 von 3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: Schritt 4, Bild 1 von 3 How to Reattach the Head of a Mailbox to the Base: Schritt 4, Bild 2 von 3 How to Reattach the Head of a Mailbox to the Base: Schritt 4, Bild 3 von 3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: Schritt 5, Bild 1 von 2 How to Reattach the Head of a Mailbox to the Base: Schritt 5, Bild 2 von 2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: Schritt 6, Bild 1 von 1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: Schritt 7, Bild 1 von 2 How to Reattach the Head of a Mailbox to the Base: Schritt 7, Bild 2 von 2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
Ziellinie
Terrell Cobbins
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 12
Letzte 30 Tage: 29
Insgesamt: 297
