Zum Hauptinhalt wechseln
How to Refinish a Scratched Wood Table
Was du brauchst
  1. How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: Schritt 1, Bild 1 von 3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: Schritt 1, Bild 2 von 3 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: Schritt 1, Bild 3 von 3
    • Flip your table over on the tabletop or on the side if applicable.
    • Get your hex keys or screwdriver.
    • Using your tool to unscrew all of the legs on the table.
  2. How to Refinish a Scratched Wood Table: Schritt 2, Bild 1 von 2 How to Refinish a Scratched Wood Table: Schritt 2, Bild 2 von 2
    • Using a damp cloth, wipe down the tabletop and all of the legs.
  3. How to Refinish a Scratched Wood Table: Schritt 3, Bild 1 von 3 How to Refinish a Scratched Wood Table: Schritt 3, Bild 2 von 3 How to Refinish a Scratched Wood Table: Schritt 3, Bild 3 von 3
    • Get the 220 grit sandpaper and cut a smaller piece.
    • Sand the tabletop until all scratches are leveled with the wood.
    • Sand all of the legs.
    • You may use a sander if you do not want to sand the table by hand.
  4. How to Refinish a Scratched Wood Table: Schritt 4, Bild 1 von 1
    • Paint all of the legs and let them dry.
    • Be sure to mix your paint to ensure it hasn't separated before applying.
  5. How to Refinish a Scratched Wood Table: Schritt 5, Bild 1 von 1
    • Paint the tabletop and let it dry.
    • If using wood paint, coat the tabletop more than once.
  6. How to Refinish a Scratched Wood Table: Schritt 6, Bild 1 von 3 How to Refinish a Scratched Wood Table: Schritt 6, Bild 2 von 3 How to Refinish a Scratched Wood Table: Schritt 6, Bild 3 von 3
    • Line up the legs with the screw holes.
    • Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
    • Attach all legs and flip the table onto its legs.
Ziellinie
Gurvir Boparai
133 Reputation
1 Anleitung geschrieben
York University, Team R-4, Melo-Thaiss Winter 2022 Mitglied von York University, Team R-4, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG4
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 50
Insgesamt: 1,162
