Zum Hauptinhalt wechseln
How to Refurbish Posts on a Cat Tree
Was du brauchst
  1. How to Refurbish Posts on a Cat Tree, How to Refurbish Posts on a Cat Tree: Schritt 1, Bild 1 von 3 How to Refurbish Posts on a Cat Tree, How to Refurbish Posts on a Cat Tree: Schritt 1, Bild 2 von 3 How to Refurbish Posts on a Cat Tree, How to Refurbish Posts on a Cat Tree: Schritt 1, Bild 3 von 3
    • Use an allen wrench to unscrew the post from the tree base.
  2. How to Refurbish Posts on a Cat Tree: Schritt 2, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 2, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 2, Bild 3 von 3
    • Using needle-nose pliers, pull and remove the staples that attach the rope to the post.
    • After the staples are removed, unwind and discard the old rope from the post.
  3. How to Refurbish Posts on a Cat Tree: Schritt 3, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 3, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 3, Bild 3 von 3
    • Using a utility knife, carefully cut the old fabric and pull it off each end of the post.
  4. How to Refurbish Posts on a Cat Tree: Schritt 4, Bild 1 von 2 How to Refurbish Posts on a Cat Tree: Schritt 4, Bild 2 von 2
    • After the fabric and rope are removed, use a soft tape measure to measure the length and circumference of the post.
    • Write the measurements down for the next step.
  5. How to Refurbish Posts on a Cat Tree: Schritt 5, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 5, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 5, Bild 3 von 3
    • Using the soft tape measure, mark the desired length on the fabric.
    • Cut the fabric to the length of the post.
  6. How to Refurbish Posts on a Cat Tree: Schritt 6, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 6, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 6, Bild 3 von 3
    • Using the soft tape measure, mark the circumference of the post.
    • Cut the fabric to the desired length.
  7. How to Refurbish Posts on a Cat Tree: Schritt 7, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 7, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 7, Bild 3 von 3
    • Place a strip of hot glue along the bottom of the fabric and fold over to hem it.
    • Line the edges of the fabric with strips of hot glue.
  8. How to Refurbish Posts on a Cat Tree: Schritt 8, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 8, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 8, Bild 3 von 3
    • Place the post on the edge of the hot glued fabric.
    • Press down to attach the fabric to the post.
    • Tightly wrap the fabric all around the post, making press the glue into it.
  9. How to Refurbish Posts on a Cat Tree: Schritt 9, Bild 1 von 2 How to Refurbish Posts on a Cat Tree: Schritt 9, Bild 2 von 2
    • Add a drop of hot glue to the secure piece of fabric.
    • Secure the top layer to the other piece of fabric by pressing down firmly until it dries.
  10. How to Refurbish Posts on a Cat Tree: Schritt 10, Bild 1 von 2 How to Refurbish Posts on a Cat Tree: Schritt 10, Bild 2 von 2
    • Line the area between the two edges of the fabric with hot glue.
    • Press down firmly to attach the two together, creating a seam.
  11. How to Refurbish Posts on a Cat Tree: Schritt 11, Bild 1 von 3 How to Refurbish Posts on a Cat Tree: Schritt 11, Bild 2 von 3 How to Refurbish Posts on a Cat Tree: Schritt 11, Bild 3 von 3
    • Place a drop of hot glue on the post where you would like the rope to begin.
    • Attach the new sisal rope by pressing it into the hot glue.
    • Wrap the sisal rope tightly around the post. Adding extra hot glue every few layers.
    • It is important to wrap the rope as tightly as possible around the post. This will keep it from coming off as your cat scratches it.
  12. How to Refurbish Posts on a Cat Tree: Schritt 12, Bild 1 von 2 How to Refurbish Posts on a Cat Tree: Schritt 12, Bild 2 von 2
    • Once the desired amount of rope is around the post, cut the excess off.
    • Place a final dab of hot glue onto the post to hold the end of the rope in place.
  13. How to Refurbish Posts on a Cat Tree: Schritt 13, Bild 1 von 2 How to Refurbish Posts on a Cat Tree: Schritt 13, Bild 2 von 2
    • Now your post is as good as new!
    • Repeat this process for as many posts as necessary.
Abschluss
Use an allen wrench to reattach the refurbished post to the cat tree.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 1,849
